small tuners for small, thin headstock http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=42900 |
Author: | John Ray [ Wed Mar 05, 2014 7:47 am ] |
Post subject: | small tuners for small, thin headstock |
Hi, I appreciate that this section is for guitars but I don't see an appropriate section. I need 5 tuners for a tiple (Canary Islands) and the head is very small and 9.5mm thick. I would prefer a high quality planetary banjo tuner but the specs say that the head must be thicker. Is that the case? Maybe those mini guitar tuners would work? thanks so much, |
Author: | Michael.N. [ Wed Mar 05, 2014 8:07 am ] |
Post subject: | Re: small tuners for small, thin headstock |
Ukulele tuners. They do a Planetary tuner for Ukes, I think by Gotoh. There are two sizes IIRC. Pegheads do some as well. |
Author: | Nick Royle [ Wed Mar 05, 2014 8:15 am ] |
These are great... http://www.pegheds.net/ |
Author: | Arnt Rian [ Wed Mar 05, 2014 9:01 am ] |
You could customize some mandolin tuners (2x4 on-a-plate); chop off one tuner from one plate and two from the other. For a more elegant sollution, get two sets, and butt the chopped ends together (either the "left" or the "right" side), for a nice looking "5 on-a-side" tuner. Better yet, and use gears etc from mathcing guitar tuners, and make your own custom tuners, like our own Haans Brentrup http://theunofficialmartinguitarforum.yuku.com/topic/114448#.UxcsGqPKyUk |
Author: | mqbernardo [ Wed Mar 05, 2014 9:41 am ] |
timely thread. i need some as well. |
Author: | DennisK [ Wed Mar 05, 2014 9:55 am ] |
Nick Royle wrote: These are great... http://www.pegheds.net/ +1 for Pegheds. Model #743A, specifically. Small and light weight, 4:1 gear ratio, and the taper matches a standard violin reamer. |
Author: | Clay S. [ Wed Mar 05, 2014 10:38 am ] |
A couple of possible solutions would be to: 1. Make the peghead thicker by inserting a thin piece of wood between the tuners and peghead. 2. Redrill the string post hole lower down and cut off the excess post length. I have used both solutions as necessary. I have also cut down 6 on a plate tuners to make 5 on a plate tuners for 5 course octave mandolins. |
Author: | ballbanjos [ Thu Mar 06, 2014 6:25 am ] |
The Stew Mac 5 Star dulcimer tuners might work--9.5 mm is about the thickest that they work on. http://www.stewmac.com/shop/Tuners/Dulcimer_tuners/Five-Star_Dulcimer_Tuning_Pegs.html Dave |
Author: | ernie [ Thu Mar 06, 2014 4:58 pm ] |
Grover 4n uke open back tuningmachines well made and cheap .I get them from a music wholesaler in naples fla that has ads on the internet. Sorry forgot the name music pros or something like it john. |
Author: | John Ray [ Fri Mar 07, 2014 1:57 pm ] |
Very helpful, thank you all. |
Author: | Nick Royle [ Fri Mar 07, 2014 2:09 pm ] |
DennisK wrote: Nick Royle wrote: These are great... http://www.pegheds.net/ +1 for Pegheds. Model #743A, specifically. Small and light weight, 4:1 gear ratio, and the taper matches a standard violin reamer. Attachment: image092.jpg ![]() (Heat up a piece of mild steel [an old file, or as I did, an old chisel] till it's glowing red, hold it there for a bit, then .. well, I quenched it, but apparently it's better to bury it in sand(?) .. and then hacksaw and file/grind to shape. I made a 2 degree template on the computer and stuck it on before hacksawing. I learned this from an OLF user so just thought I'd try to help someone else with it. ![]() Worked supremely well all things considered. |
Author: | RusRob [ Sat Mar 08, 2014 2:45 pm ] |
Thanks for the info on this thread guys. I just took in a no name kid's guitar that needs tuners and everything I have is too long, so this thread is pretty timely for me. +1 to all, Bob |
